AmitR
May 08, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 + Homekit
We’ve been monitoring issues that some users have experienced on OrbiOS 2.1.4 with Apple Homekit. In response, to those customers, we’re releasing firmware that provides a temporary work around to c...
chadkh71
May 09, 2018Tutor
Hello! The new Orbi software DID hose my HomeKit. I've been problem solving for days now - most of my devices say "no response."
I'm pleased to see that there is a hot fix out, but my MacBook doesnt actually have an ethernet port, and I don't have a dongle, so what do I do?
How many days before a permanent fix is out, that will upload over the air?
Chad
usahale
May 09, 2018Star
Chad,
Just download the img file(s) to your Mac, login to your Orbi, Advanced, Administration, Firmware Update, Manual. Do the sat first, when it’s rebooting do the router. No dongle or hard connection needed. It’s working great for me. Good Luck.
- chadkh71May 09, 2018Tutor
Great! I did it and it worked. (Some article said it needed an ethernet connection.)
- DarrenMMay 10, 2018Sr. NETGEAR Moderator
The Links for the RBR40 RBS40 and RBY50s have been all updated to the correct files.
DarrenM
DarrenM
- turns2stoneMay 10, 2018ApprenticeThanks. Now that the correct RBS50Y firmware was posted, all satellites are behaving nicely with HomeKit.
- IssyGalMay 17, 2018Aspirant
Netgear should add this bit of instructions for MacBook pro owners with USB-C only connections. I did not want to buy a dongle just for this process.I was able to upload the firmware via web and my Homekit is alive again so far.
- cheshbrMay 17, 2018Apprentice
IssyGal, I have no idea what you are trying to say in your post about MacBook Pro owners with USB-C only. You seem to have answered your own post. I’m interested in what you say as I am a MacBook owner with USB-C only. Please clarify
To Cheshbr,
Sorry... I had hit the "Reply" button to Message 24 and hoped my comment would appear right below it. The instructions to install the firmware mentioned connecting your Ethernet cable to your computer which you can't do with the latest MacBook Pros as there is no Ethernet cable connection.
