AmitR
May 07, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 + Homekit
We’ve been monitoring issues that some users have experienced on OrbiOS 2.1.4 with Apple Homekit. In response, to those customers, we’re releasing firmware that provides a temporary work around to c...
AC641
May 11, 2018Luminary
Updated to v2.1.4.14 on both RBR50 and RBS50 (satellite first). The update went smoothly. It will take me a few days to determine whether it has cured my issues with Philips Hue Routines becoming unreliable; here's hoping!
AC641
May 14, 2018Luminary
After four days my Hue Routines have been faultless. I'll give it at least a couple of weeks before stating that v2.1.4.14 has definitely cured my Hue issue but it's promising so far.
- EagleKlawMay 14, 2018Tutor
Ok, so after going through the weekend, my system has been mostly stable. The one thing that I am noticing is that when I am inside my local network, my HomeKit stuff reports and functions nearly flawlessly with all devices reporting the correct status; however, when I am outside my home accessing the system remotely it is very sporadic. Sometimes everything reports as "no response" and sometimes only random devices (but typically hue based) report as "no response", and sometimes it reports correctly.
Anyone have any ideas on what could cause this behavior or seeing similar?
- eljarvisoMay 14, 2018LuminaryWhat are you using as your HomeKit hub while you are away? I’m using an Apple TV 4K. If you use something like an iPad there might be issues with slow wifi reconnect when requesting HomeKit status.
- cheshbrMay 14, 2018Apprentice
I have an Apple TV 4th gen and a HomePod. Both are on 100% of the time
- fcwestMay 14, 2018Star
I'm seeing the exact same behavior using Apple TV 4K as HomeKit hub.
- eljarvisoMay 16, 2018Luminary
I haven't seen the problems but it might be something to do with my setup. I have a seperate router and am running the Orbi's in AP mode. I have an Apple TV 4K as my main hub and a regular Apple TV 4 as backup. Maybe there is some blocking when Orbi is running in router mode.
