AmitR
May 07, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 + Homekit
We’ve been monitoring issues that some users have experienced on OrbiOS 2.1.4 with Apple Homekit. In response, to those customers, we’re releasing firmware that provides a temporary work around to c...
Binaries
May 25, 2018Aspirant
I am also having major Homekit connection issues. I tried to download this firmware but the link is not working. Can someone please help? I get the error message "Requested File does not exist" and asking for a File code. I am looking for RBR50 and RBS50. Thanks in advance!
Retired_Member
May 25, 2018Also not able to download the beta firmware. Getting "Requested file does not exist!" Really thinking of returning the kit fo Costco. But what's the alternative???
- DNichterMay 25, 2018Star
I would return it while you can. I have had nothing but problems. Eero is supposed to work great with HomeKit and other Apple gear. I'd suggest that.
- AC641May 25, 2018Luminary
I've uploaded the v2.1.4.14 (Homekit Fix) files to my Dropbox account; here are the links if you'd like to download:
RBR50: https://www.dropbox.com/s/y2wb8ypc5ks5sq6/RBR50-v2.1.4.14.img?dl=0
RBS50: https://www.dropbox.com/s/0oxmjpw9zngvcgn/RBS50-v2.1.4.14.img?dl=0
Let me know if you have problems downloading (I don't use Dropbox often).
It has now been over 2 weeks since I installed this firmware and I have had zero issues with Philips Hue since.
- Retired_MemberMay 25, 2018
Thanks AC641! What ISP are you using Orbi with? FIOS? Internet stable since installing 2.1.4.14? Also, Since this firmware is technically newer with a higher version number, the auto-update isn't wiping it out, right?
Eero looks promising, but I love how the RBR50 and RBS50 have so many ethernet ports and I fully utilize them. Getting Eero would involve adding switch boxes. Also, the 2nd gen Eero doesn't have a USB port. I'm using an old trusty workhorse HP laserjet printer that I need the USB connection for. I'm going to try the beta firmware and see if that alleviates my Homekit issues.
- cheshbrMay 25, 2018Apprentice
Here’s a link to someone who has saved the firmware in his Dropbox account
https://community.netgear.com/t5/Orbi/OrbiOS-2-1-4-Homekit/m-p/1577706#M32231
- riccioloMay 25, 2018Aspirant
Anybody with RBK40 firmware version?
