AmitR
May 07, 2018NETGEAR Employee Retired
OrbiOS 2.1.4 + Homekit
We’ve been monitoring issues that some users have experienced on OrbiOS 2.1.4 with Apple Homekit. In response, to those customers, we’re releasing firmware that provides a temporary work around to c...
Retired_Member
May 25, 2018Also not able to download the beta firmware. Getting "Requested file does not exist!" Really thinking of returning the kit fo Costco. But what's the alternative???
DNichter
May 25, 2018Star
I would return it while you can. I have had nothing but problems. Eero is supposed to work great with HomeKit and other Apple gear. I'd suggest that.
- AC641May 25, 2018Luminary
I've uploaded the v2.1.4.14 (Homekit Fix) files to my Dropbox account; here are the links if you'd like to download:
RBR50: https://www.dropbox.com/s/y2wb8ypc5ks5sq6/RBR50-v2.1.4.14.img?dl=0
RBS50: https://www.dropbox.com/s/0oxmjpw9zngvcgn/RBS50-v2.1.4.14.img?dl=0
Let me know if you have problems downloading (I don't use Dropbox often).
It has now been over 2 weeks since I installed this firmware and I have had zero issues with Philips Hue since.
- Retired_MemberMay 25, 2018
Thanks AC641! What ISP are you using Orbi with? FIOS? Internet stable since installing 2.1.4.14? Also, Since this firmware is technically newer with a higher version number, the auto-update isn't wiping it out, right?
I'm in the UK and I use the EE 4G network for my home broadband. I live in a rural area and there's no fibre or decent broadband speeds via the phone line so I have ditched it entirely. I have no idea what FIOS is or means. The firmware has not been overwritten by Auto-Update,
Eero looks promising, but I love how the RBR50 and RBS50 have so many ethernet ports and I fully utilize them. Getting Eero would involve adding switch boxes. Also, the 2nd gen Eero doesn't have a USB port. I'm using an old trusty workhorse HP laserjet printer that I need the USB connection for. I'm going to try the beta firmware and see if that alleviates my Homekit issues.
