raykag
Apr 28, 2018Guide
OrbiOS 2.1.4.10 kills Internet access if you use Ethernet back haul
I'd been happily using the RBK50 Orbi AC3000 single satellite system since June of 2017 and started using ethernet back haul succesfully around October 2017. Typically 8-16 connections at any given ...
- Oct 04, 2018
I updated my firmware to 2.2.1.210 today and it solved the ethernet back haul taking the internet connection down and eliminated a couple of other oddities that I was experiencing.
Elofi
Apr 29, 2018Tutor
I have the same issue. I have RBR50 and and two RBS50 connected through wire due to poor signal, everything was working fine and smoothly. however, the new firmware made some devices unable to connect to the LAN and if connected; the internet is not available. When I reveret back to the old firmware, everything went normally. The problem is the firmware is automatically updated without my knowledge and the problem keep occuring.
I found the Daisy chaining feature enabled in the new released firmware, and I disabled it; however, did not resolve the issue. Additionally, when disconnecting the RBS50 and only working on RBR50, the devices can connect to the router and able to use the LAN and internet enabled.
Kindly, if you found how to resolve it, please share.
Thank you.
Elofi
Apr 29, 2018Tutor
Hi all
the resolution is in different thread "Re: OrbiOS 2.1.4 availability" by disabling the daisy chaning network and reboot all the devices.
Good luck all.
