sohammistry95
Apr 28, 2018Star
OrbiOS 2.1.4.10 on RBK30 feedback
During testing phase of OrbiOS 2.1.3.-- It fixes alot's of issue that we were having. After Netgear finally rolling out 2.1.4.10 I'm very pleased to say this is one best release. Netgear has fixes al...
Apr 28, 2018Guru - Experienced User
Try locating v2.1.4.10 for your satellite model here?
https://www.netgear.com/support/product/orbi.aspx
You can manually download the file and manually install it if there is an update avaiable.
sohammistry95
Apr 29, 2018Star
Thanks for the reply. But the problem is Netgear hasn't release the 2.1.4.10 to RBW30 "mini satlilite". Netgear didn't release entire OrbiOS 2.1.4.10 weblink for all Orbi devices for manual update. So, I couldn't find the update for RBW30.
I also heard on Orbi tread is that if satalite is running older & Base running newer version then entire Orbi system will be unstable and Orbi will run un efficiently,
So, anyone Please get in touch with Netgear and release the update???
