thebishop's avatar
thebishop
Apprentice
Dec 05, 2017
OrbiOS 2.1 ethernet backhaul - only 10Mbps
Great that ethernet backhaul was just added. Unfortunately, I can't get more than 10Mbps when connecting to the satellite that uses it - neither using a hardwire connected to the satellite, nor using...
  • thebishop's avatar
    Dec 05, 2017
    Ok, it seems to have to due to the fact that my client device was set manually to 100mbps since previously - changing it to auto detect would give a 1gbps link that seems to work as expected. Let’s disregard this for now until further testing....
