JimSweden
Apr 30, 2018Star
OrbiOS 2.4.1 - Total mess
2.4.1 is an unbelievably bad firmware upgrade!! The router restarts every 2-3 minutes (observed in http://orbilogin.com/RST_statistic.htm). All wireless devices disconnects after a few seconds (often...
Zdman
Apr 30, 2018Guide
I too have had issues with wired backhaul and the latest firmware. I found that no matter what I did, the satellite would eventually revert to wireless backhaul and connect via a very low signal back to the router. I think this was then causing network loops as my entire network would start having issues ( basically there are two routes to the satellite). I tried downgrading firmware manually on the satellite and that worked, but the next day the satellite had auto updated the firmware again (Netgear not allowing you to keep older fw that works while they push out new poorly tested fw is a joke). Anyway, I have now stabilized things based on info from another forum that I will not name.
Here is what I did:
1. Point your browser to the satellite that you want to use wired backhaul but change the url to .......debug.htm. Then enable telnet.
2. Using telnet, log into your satellite (same username and password as used on router)
3 Type the following:
brctl stp br0 1
this will turn on spann8ng tree protocol. Why it is off is anyone’s guess, but my understanding is it stops the crazy traffic loops. After doing this and waiting about 5 minutes, my satellite went to wired backhaul and so far has stayed there. And, no other network instabilities hav occurred
4. Go back to the debug page and disable telnet.
Note that this fix fix is not persistent, meaning that if you power off the satellite you have to repeat the steps above. If anyone knows how to save this as persistent, please speak up.
- FURRYe38Apr 30, 2018Guru - Experienced User
For your configuration, do you have any network switches in between the router and satellite? If so, whats the mfr and model# of the switch?
Here is what I did:
brctl stp br0 1
- ZdmanApr 30, 2018Guide
No I do not. However, my satellite is quite far from the router (450 feet) as it s in my guest house. So I use two Enstation 5 ac units as the wired bridge. When I started having issues I did wire directly with a cable at about 100 feet with the same results so I don’t think the enstation link was an issue. Also, this setup worked up until the last fw update. It would really be nice to have a setting on the satellite where we could force it to wired uplink -as I noted above, it seems odd that a satellite would prefer a very week wireless backhaul to a high quality wired one
Ok, just checking. Seen issues with managed switches vs non managed.
Seems that they probably have changed someting in the FW. :smileyfrustrated:
