AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
Aquatechie
Feb 18, 2018Tutor
As instructed when I first set up the Orbi a week ago, my base station was upgraded to Firmware version 2.1.2.18; I unplugged and plugged the 2 satellites (numerous times) and they stiill maintain their Firmware versions at 2.1.2.2. The result of the upgrade has caused my Apple TV (A1427) to no longer see the wifi signal - even with a satellite installed inches away. Suggestions?
- JCinNCFeb 18, 2018Guide
bring them into the same room as the router. Once on the correct version return them to their original location. NG tech support had me do that yesterday when we were trouble shooting the password/security/DHCP issue and it helped.
I personally would manually downgrade all three devices to 2.0.1.74
