AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
Mar 08, 2018Guru
What version of FW is currently loaded?
You can phone contact NG support and see if they have a beta available to use...
Try some of the following:
Disable Beamforming, MIMO, Daisy Chain or Fast Roaming if you have any of these features.
Orbi2018-3-3wrote:
I’m a brand new owner and highly disappointed with the connection drops. I’d like to assist in firmware testing if needed before I hit the “return to Costco” option. I’m an IT guy, but not a network specialist. I’m listening here for options.
Orbi2018-3-3
Mar 08, 2018Tutor
My firmware is 2.0.1.4. I just wasn’t sure on how to get the beta versions because (probably for good reason) they aren’t typically available. I haven’t adjusted any settings so unless they options you mentioned are on by default they should be off. I’ll explore more.
- FURRYe38Mar 08, 2018Guru
Most of those options are enabled. So check to and test them disabled. Others have said it's helped.
Can ask NG support. Sometimes they might have something for a beta.
