AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
Orbi2018-3-3
Mar 08, 2018Tutor
My firmware is 2.0.1.4. I just wasn’t sure on how to get the beta versions because (probably for good reason) they aren’t typically available. I haven’t adjusted any settings so unless they options you mentioned are on by default they should be off. I’ll explore more.
Mar 08, 2018Guru - Experienced User
Most of those options are enabled. So check to and test them disabled. Others have said it's helped.
Can ask NG support. Sometimes they might have something for a beta.
