AmitR
Feb 13, 2018NETGEAR Employee Retired
OrbiOS MR 2.1 issues
I wanted to reach out to provide a quick update on OrbiOS 2.1 software. We believe that these issues are affecting some users. Rest assured that we've been following this issue and working hard beh...
Apr 06, 2018Guru - Experienced User
Was a factory reset performed on BOTH router and satellites after updating to v2.1.3.4? This needs to be done.
How are you setting up the Satellites?
I recommend setting up the satellites to sync via wifi first. Then after they are set up via wireless, connect the ethernet cable to one satellite first. Give it 5 minutes for the system to reconfigure itself. Once it's done, check someting connected to the satellite, wired PC or wireless device. Should have connection here. Satellite should have displayed BLUE led.
Then connect next Satellite and wait 5 minutes.
Remove the switches as a test to see if they connect directly to the router.
Swap out LAN cabling as well. CAT6 recommended.
Others are getting theres set up:
How I got mine working. Two non managed switches in between.
