AmitR
Oct 03, 2018NETGEAR Employee Retired
OrbiOS MR 2.2.1 available
In the next few days, we're going to be publishing OrbiOS MR 2.2.1. Key new features in this release include:
- Support for Orbi Voice (if you have or are planning to get one, you'll need to upgrade the Router to MR 2.2.1)
- Orbi Outdoor support for International Regions (EU & Australia/New Zealand)
- Stability & performance related bug fixes
- Ethernet Backhaul bug fixes
You can use the Orbi Mobile App (or WebUI) to upgrade your system, or it'll automagically upgrade over the next few days.
Orbi Product Management.
1 Reply
Any one upgrading to this FW and experiencing problems, please try a full factory reset on the entire system and setup from scratch as a last resort to see if this helps. One user has posted it helped him:
