picsou123's avatar
picsou123
OrbiOSV2.3.1.48 + Homekit
Bonjour
j ai un orbi rbr50 avec le firmware V2.3.1.48 , et homekit ne fonctionne pas ( meme avec le precedent firmware cela ne fonctionnait pas).
Ma configuration :
- livebox ( wifi desactivé).
- routeur orbirbr50 branche en ethernet en mode routeur.
- satellite avec le firmware V2.3.1.48
- detecteur eve room a distance proche du satellite
Des que je m eloigne du satelitte , ou en 4G dans l application Maison les appareil sont sans reponse.
y a til une solution? merci
  • FURRYe38's avatar
    en anglais s'il vous plaît
    picsou123 wrote:
    Bonjour
    Ma configuration :
  • (I thought this was an English forum?)
    Anyway, I can confirm that the .48-firmware also broke my HomeKit setup that's been running stable for a long time with many differen FW versions.
    I've had issues way in the past but they were fixed a long time ago, but the issue seems to unfortunately have resurfaced again with V2.3.1.48.  Besides this issue the rest seems to work just fine. Hoping for a quick fix!
    • FURRYe38's avatar
      This is a English forum. You posted in French.
      Try a factory reset and setup from scratch to see if this solves this.
      What FW version were you using when Homekit was working?
      • angr's avatar
        angr
        Star
        No I didn't. I replied to a post in French. Notice the difference.
        I prefer to wait until Netgear fixes it. Performing a factory reset and setting up things from scratch will take me at least a day, probably longer. I think the vendor needs to do their part first to resolve this. HomeKit has worked fine on most FW versions up until now with .48.
