Orbipro1
Jul 27, 2021Aspirant
Orbipro rip setting no off command
Is rip safer set to in only, out only, or none? I use one router. There is no none on orbipro drop down setting. do not want to send or respond to rip packets. netgear posted instructions:...
- Jul 27, 2021
Sorry found the answer:
- RIP Version: This controls the format and the broadcasting method of the RIP packets that the router sends. (It recognizes both formats when receiving.) By default, this is set for RIP-1.
- Disabled will disable the RIP feature completely.
- RIP-1 is universally supported. RIP-1 is probably adequate for most networks, unless you have an unusual network setup.
- RIP-2 carries more information. Both RIP-2B and RIP-2M send the routing data in RIP-2 format.
- RIP-2B uses subnet broadcasting.
- RIP-2M uses multicasting. (See note below.)
Jul 27, 2021Guru - Experienced User
Please post about this over in the Orbi Pro forum:
https://community.netgear.com/t5/Orbi-Pro-WiFi-for-Small-Business/bd-p/en-business-orbi-pro
Thank you.
