Orbipro1's avatar
Orbipro1
Orbipro rip setting no off command
Is rip safer set to in only, out only, or none?  I use one router.  There is no none on orbipro drop down setting. do not want to send or respond to rip packets.   netgear posted instructions:...
  • Orbipro1's avatar
    Orbipro1
    Jul 27, 2021
    Sorry found the answer:
    • RIP Version: This controls the format and the broadcasting method of the RIP packets that the router sends. (It recognizes both formats when receiving.) By default, this is set for RIP-1.
      • Disabled will disable the RIP feature completely.
      • RIP-1 is universally supported. RIP-1 is probably adequate for most networks, unless you have an unusual network setup.
      • RIP-2 carries more information. Both RIP-2B and RIP-2M send the routing data in RIP-2 format.
      • RIP-2B uses subnet broadcasting.
      • RIP-2M uses multicasting. (See note below.)
