dobiegillis
Apr 07, 2017Aspirant
Orbir will not connect to a wired connection
I installed an Orbi system replacing an Asus router. The Wi-Fi is blazing fast, but any wired device does not get an internet connection. My home is Cat 6 wired throughout and I use 2 Ethernet switch...
- Apr 12, 2017
Solved: For whatever reson while troubleshooting the Orbi with tech suppport we changed the MTU Size to 1500 and it started working.
dobiegillis
Apr 12, 2017Aspirant
myblade
Apr 12, 2017Tutor
Do you know the setting of MTU size before the change? 1500 is pretty standard for normal Ethernet.
- dobiegillisApr 12, 2017Aspirant
If I recall it was at a default of 1800. I could be wrong I have slept since then. :)
