RoadGlide101's avatar
RoadGlide101
OrbiRBR 50 satellites
I have a RBR50 and we moved to a new much larger home.  It is old and has some plaster and lathe walls.  How many satellites can i add on to the router and can a satellite work from another so they a...
  • CrimpOn's avatar
    CrimpOn
    Oct 16, 2019
    If you have the RBR50 router, the satellites which mesh "best" with it are the RBS50.  ANY Orbi satellite will function with any Orbi router.  The "50" series have more powerful radios and a higher speed WiFi backhaul than the others.  If a lower speed satellite is paired with the RBR50, the backhaul speed will drop to the speed of the satellite.
