atramsay
Apr 19, 2020Follower
OrbiRBR20 with Netgear D7000
Just bought Orbi RBR20 to improve signal around the house. Currently have Netgear D7000 Nighthawk modem/router. Will it work with my RBR20?
DarkNet
Apr 24, 2020Apprentice
Do you want to keep your Nighthawk functioning as your router and use the RBR20 for your home wifi? That’s what I would do anyway. You can put your RBR20 in AP mode and hardwire connect to your Nighthawk. Disable wifi in the Nighthawk and let the RBR20 and RBS20’s (assuming you have those too) handle the wifi. Should work just fine.
