bingoblake
Aug 10, 2018Aspirant
OrbiRBR50 adding a Orbi outside
I have a Orbi RBR50 and am adding an Orbi outdoor unit to the mix. Once I added it to the mix one of my slaves disappeared and I cant get the system to recognize anymore. I am trying to extend to m...
Aug 10, 2018Guru - Experienced User
The new unit is an RBS50Y? (I'm wondering because you put in EX2700 as the model number).
Does the shop satellite still show up in the Orbi's web ui (perhaps classified as "disconnected")? Or is it completely missing? If you turn off the RBS50Y are you still able to connect to the WiFi Network?
BTW, you do need to enable the daisy chain mode on the router if you want to relay the shop satellite's backhaul through the RBS50Y.
- bingoblakeAug 10, 2018Aspirant
Thank you for replying! Please ignore the model number it was challenging to find the correct model number with the drop down menu.
It is a RBR50 purchased with two RBS50 satellites and one RBS40 satellite added and an Orbi Outdoor satellite just added. When I look at the network map in the app I only see Router, Sat 1 (RBS40) connecting the Outdoor unit and a single Sat 2 (RBS50) the SAT 3(RBS50) which is in the shop is missing from the map?
How do I enable daisy chain mode?
- StephenBAug 11, 2018Guru - Experienced User
Use the browser interface. Choose the "Advanced" tab, then "Advanced Setup" and "Wireless Settings" There's a check box there for "Enable Daisy-Chain Topology"
I believe that's an bug in the app (not always handling more than 2 satellites correctly). Try using the browser interface, and report back if you don't see the satellite there.
- bingoblakeAug 11, 2018Aspirant
Thank you! Daisy chain was enabled. I can see 4 satellites on browser interface, should I assume that the router won't occupy one of those "satellite" sites? If so then all 4 are working even though they don't show on phone interface.
