Orbiwanbenobi
Jul 03, 2019Aspirant
OrbiRBR50 Ethernet Connectivity Problem
I've just recently upgraded my router to the OrbiRBR50 from an older Nighthawk7000 that died during a thunderstorm surge. The wifi and satellite set up was easy and seamless. All wireless devices in t...
Jul 03, 2019Guru - Experienced User
Try a different wired device connected to the Orbi.
Try different ports on the back of the RBR or RBS.
Try a different LAN cable.
Possible that your LAN port on the Mac could have been damaged. Thus maybe your R7000 could be ok.
