KouroshMDC
Nov 06, 2019Aspirant
Orbi(RBR50) Keeps crashing / Disconnecting
I have Fios modem and router. Because of this our orbi is set to AP mode. We recently had a problem so my personal IT guy reset the system, updated it to the latest firmware and set it to AP mode, wi...
KouroshMDC
All router and satelittes are within 10-30ft of each other. I manual updated the orbi as shown on the website. When I login into orbilogin it says all the router and satlellites are up to date. I still did a manual update with the link provided. After it updated it still remained the same. After this I turn off each router and satelitte one by one.
Nov 06, 2019Guru - Experienced User
RBS should not be with in 10 feet or 20 feet of the RBR. Starting distance with the RBS from the RBR is 30 feet. Depending upon building materials, too close to the RBR may bring too much wifi signal over lap between the RBR and RBS.
KouroshMDC wrote:All router and satelittes are within 10-30ft of each other. I manual updated the orbi as shown on the website. When I login into orbilogin it says all the router and satlellites are up to date. I still did a manual update with the link provided. After it updated it still remained the same. After this I turn off each router and satelitte one by one.
