zawa01
Jan 16, 2019Follower
OrbiRBS50 Macbook won’t connect
I’ve been having trouble with connectivity for a while now. The wifi disconnects constantly, but now it won’t connect at all. I’ve tried troubleshooting through the Mac and have moved the router next to the computer. It keeps telling me that the network can’t be joined.
Try forgetting the wifi profile on the mac for the SSID name then try to reconnect again.
What OSX version are you using on the Mac?
What FW is currently loaded?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
What WPA security modes are you using? Try WPA2 and AES only.
Be sure the BeamForming and MIMO are enabled.
zawa01 wrote:
I’ve been having trouble with connectivity for a while now. The wifi disconnects constantly, but now it won’t connect at all. I’ve tried troubleshooting through the Mac and have moved the router next to the computer. It keeps telling me that the network can’t be joined. - Blanca_ONETGEAR Employee Retired
Hi zawa01
Welcome to NETGEAR Community!
- Do you have a device wired to the router? Is it online?
- Please describe router ring light.
- Does it affect all wireless devices?
- Kindly describe your network setup (ISP, modem, devices connected)
Blanca
Community Team
