OrbiUser1212's avatar
OrbiUser1212
Follower
Feb 20, 2021
OrbiRBS50 stopped showing link rates
Noticed after present firmware uodate, that my Orbi RBS50 satellites no longer show the link rate for connected devices. Tried rebooting and that didn't help.  Interestingly enough, the main router RBR50 is still showing link rates for connected devices even though it had the same firmware update.
  • CrimpOn's avatar
    CrimpOn
    My Android Orbi app (v2.1.0.1395) is the same.  (Orbi Firmware 2.7.2.104) RBR50 router shows Link Rate, RBS50 satellite does not, RBS40V does.  Scott's Excel SOAP spreadsheet does not get Link Rate or Signal Strength from devices connected to the satellite.
    Looks like an "oops" in the new satellite firmware.
    Also, the Android Orbi app now appears to think that Parental Controls is "on" and believes I have 113 devices in my "Home".  34 connected and 79 not connected.  Orbi web interface does not contain any link to Parental Controls. Perhaps that is now an "app only" feature? (Like sound control on the RBS40V can be done only on the app, not from the RBS40V web menu or Orbi router menu.)
  • Yes I experienced the exact same problem on my RBS50. All deviced attached to it shows N/A as link rate and the wifi signal icon is always 100% (before several devices were 2 bars).
    Everything is working as before but it would be nice if Netgear patched this so we can once again see precise connection statuses.
    I have also noticed two devices attached to my satellite do not show up any longer in my "attached devices" list. If I log into the satellite and check, they are there but both the Orbi app and the direct connect via Browser do not list them at all. This is only 2 out of about 65 devices.
    • Cooker44's avatar
      Cooker44
      Initiate
      Same issue here. No link rates being shown. I have two RBS50 and one RBS20 with RBR50 router
