OD6572
Jan 22, 2022Aspirant
Orbis RBS50 satellite crashes network with ethernet backhall
I have had the Netgear Orbi router with one satellite for the past year and it has worked flawlessly. I have one satellite that was connected through Ethernet backhaul. Up to three days ago, my n...
Jan 23, 2022Guru - Experienced User
What do you mean by crashing>?
Did you first wirelessly sync the RBS to the RBR fully, then ethernet connect the RBS to the RBR?
Is the RBS directly connected to the RBR or is there a LAN switch or patch panel in between them?
Try swapping LAN cables. CAT6 is recommended.
Try connecting the RBS via ethernet to the back of the RBR while in the same room as the RBR.
OD6572
Jan 23, 2022Aspirant
By crashing I mean, devices on the network look connection. Most of them at first lose their connection to the
WAN and then LAN connections seem to be intermittent and very slow if they respond at all.
I sync and connect the satellite wireless and then connect a LAN (CAT 5e) and after a short time, devices start to have problems.
There is a 16 port switch involved. I guess I could try and bypass the switch and see if anything changes. Nothing has changed on my network as far as hardware when the problem started.
