bbrown43
Nov 19, 2017Aspirant
Orbi's Speeds is a fraction of my routers
Hey guys, I'm having a couple issues right now with my home network. Things were going great for a while, but I decided to run a speed test today, and now, I'm noticing some issues. For my gear, ...
RogerSC
Nov 19, 2017Virtuoso
Can you please describe more about what you're doing? Do you have the Orbi in AP mode, or in router mode? Is your Arris in bridge mode, or is wireless turned off on it. The way that I would connect this up is to turn off the wireless in the Arris, use the Orbi in AP mode. You would connect the Orbi internet port to a LAN port of the Arris, and switch the Orbi to AP mode.
Could you please describe how the pieces are configured, and how they're connected?
Thanks!
- bbrown43Nov 19, 2017Aspirant
Right now my Orbi is set in router mode and is connected to the Arris via the LAN ports. Wireless is turned off on the Arris, and DMZ is enabled as well. I'm not sure what you mean by bridge mode, but I don't think that's on either.
- RogerSCNov 19, 2017Virtuoso
Having the Arris in bridge mode would make it essentially just a modem, and then the Orbi would be in router mode, doing all the router functions. That's one way to do it, but if you don't have the Arris in bridge mode, and have the Orbi in router mode, then you may be doing double NAT, and that will slow the Orbi down a lot. If both the Arris and Orbi are doing NAT, then the wireless on the Orbi will be slower than you'd like.
So what I would do to fix this is one of these:
1. Use the Arris as your router, but turn off wireless on it. Then put the Orbi in AP mode, as I mentioned before, and connect the Orbi internet port to one of the Arris's LAN ports. No DMZ, don't use DMZ for this. Just a wired connection between the Arris and the Orbi.
2. Put the Arris in bridge mode, so that the Arris isn't doing routing or NAT or anything. Then connect the internet output of the Arris to the internet input of the Orbi, and set the Orbi in router mode. So the Orbi is doing all the router, NAT, and wireless functions. Again, no DMZ use here.
The common areas of the configurations above are that the Orbi is connected to the Arris via an ethernet cable. There is no use of DMZ on the Arris. And only one router, either the Arris or the Orbi. If you can't put the Arris into a transparent (bridge) mode where it doesn't do rounting and NAT, then the Orbi will have to be in AP mode. The Orbi should not be in router mode if it is connected to a router that's doing routing and NAT *smile*.
Personally, I prefer #1. above, but you may not be able to turn off routing and NAT on the Arris, I don't know.
Hope I haven't confused you...please feel free to ask more questions!
- bbrown43Nov 19, 2017AspirantPutting the Arris in bridge leads to a constant pink light on the orbi, and no connection at all.
