bbrown43
Nov 19, 2017Aspirant
Orbi's Speeds is a fraction of my routers
Hey guys, I'm having a couple issues right now with my home network. Things were going great for a while, but I decided to run a speed test today, and now, I'm noticing some issues. For my gear, ...
bbrown43
Nov 20, 2017Aspirant
So to clarify, you're suggesting I put the modem in Bridged, but still put the Orbi in AP instead of router mode?
Also, how will this affect my port forwarding? Should all the port forwarding be done on the Arris or on the Orbi?
Right now, with the DMZ configuration, I get around 380 Mbps, whereas on the satellite I get closer to 270 (Both hardwired connections.) Is that a typical dropoff or is that abnormal as well.
Thanks again!
RogerSC
Nov 20, 2017Virtuoso
bbrown43 wrote:So to clarify, you're suggesting I put the modem in Bridged, but still put the Orbi in AP instead of router mode?
Thanks again!
No, if the Orbi is in AP mode (recommended), then the Arris must be in router mode. And I would turn off wireless on the Arris as well.
I don't do port forwarding, but that's done in the Arris (router functions), not in the Orbi if the Orbi is in AP mode. So setting up your port forwarding in the Arris in router mode should be just fine.
