jp4120
Jan 02, 2022Guide
orbit 2 satellite system - rbr30 and 2 satellites - speeds seem off
good wifi speeds from areas near base and near 1 satellite - last couple days very slow from a second satellite that used to work fine - any suggestions on what to look for other than swap the 2 sate...
Jan 02, 2022Guru - Experienced User
I would try swapping the satellites just to see if its a specific device issue or if its related to the location.
Easy enough swap to check that.
If its related to the location, then you'd just try moving the troublesome satellite around a bit.
