jp4120
Jan 02, 2022Guide
orbit 2 satellite system - rbr30 and 2 satellites - speeds seem off
good wifi speeds from areas near base and near 1 satellite - last couple days very slow from a second satellite that used to work fine - any suggestions on what to look for other than swap the 2 sate...
Jan 02, 2022Guru - Experienced User
I would try swapping the satellites just to see if its a specific device issue or if its related to the location.
Easy enough swap to check that.
If its related to the location, then you'd just try moving the troublesome satellite around a bit.
jp4120
Jan 02, 2022Guide
yeah i'll give it a shot - pain in the neck since every time i move these around there is difficulty in getting everything optimal again - i was wondering if its common to hear of 1 satellite failing and a purchase of a single satellite is the cure.....because rather than spend $150 or more on a satellite i will just replace the entire system - with whatever is currently best of breed and under$500 so either newer Orbi or a Nest or something else.
- plemansJan 03, 2022Guru - Experienced User
I have heard of satellites failing before. I've also heard of firmware being corrupt. Or something in a home being rearranged that causes issues. One time it was a peice of furniture that had foil lined insulation in it that caused blockages. Its why you have to see if its an issue with a specific satellite or with location.
If you find out it is the satellite, then we can work on trying new firmware because sometimes firmware does get corrupted and needs to be reinstalled.
