Gater
May 23, 2019Follower
Orbit Guest Network Always at 2.4Ghz
There don't seem to be any options to set this, but my guest Network forces everyone to 2.4Ghz. There also doesn't appear to be a way to set up two guest networks (2.4/5). The standard network allows ...
CrimpOn
May 23, 2019Guru - Experienced User
Gater wrote:
There don't seem to be any options to set this, but my guest Network forces everyone to 2.4Ghz. There also doesn't appear to be a way to set up two guest networks (2.4/5). The standard network allows devices to choose, the issue is with the guest Network. Is there a solution?
My experience does not match yours. I turned on the Orbi guest network and "broadcast SSID". My Lenovo laptop immediately connected to the Orbi at 5G. I will charge the battery on one of my old mobile phones and try it as well, but my guess is the result will be the same.
It seems to be the consensus on this forum that the device decides which band it will use, not the Orbi. I have been on the forum for some time, and one of the frequent complaints is that devices select the "wrong" connection (i.e. not the closest router/satellite, the wrong "band", etc.) What seems obviously the optimal connection (to us) is often not the connection that devices have chosen.
This is not to say that YOUR Orbi behaves live mine. I would, however, suggest some controlled tests. Find something that is connecting at 5G on the primary network (like my laptop), then attempt to connect to the Orbi guest network with it.
