Gater
May 23, 2019Follower
Orbit Guest Network Always at 2.4Ghz
There don't seem to be any options to set this, but my guest Network forces everyone to 2.4Ghz. There also doesn't appear to be a way to set up two guest networks (2.4/5). The standard network allows ...
May 24, 2019Guru - Experienced User
Gater wrote:
There don't seem to be any options to set this, but my guest Network forces everyone to 2.4Ghz. There also doesn't appear to be a way to set up two guest networks (2.4/5). The standard network allows devices to choose, the issue is with the guest Network. Is there a solution?
CrimpOn
Did another test. Powered up my old Moto e4, selected "My Guest", and it connected at 5G. Of course, I am sitting at my desktop computer in the same room as the Orbi router, so I have strong WiFi signals.
