MatheusFigueire
Aug 28, 2019Aspirant
Orbit RBR50 dropping connection
ORBI RBRB50 with Firware V2.3.5.30 is dropping connection. After update of some versions, this beahviour is happening. I thought with the updates of this last version it would stop, but it coninues...
Aug 28, 2019Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
Has a factory reset and setup from scratch been performed since last update?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
MatheusFigueire wrote:ORBI RBRB50 with Firware V2.3.5.30 is dropping connection.
What can be done from NetGear ?
- MatheusFigueireAug 30, 2019Aspirant
rbr50
Hi, thanks for the post.
I will try to do some stuffs, but llike i said in the post above, it should work without any special configuration, at leat the basic.
Thanks.
