MatheusFigueire
Aug 28, 2019Aspirant
Orbit RBR50 dropping connection
ORBI RBRB50 with Firware V2.3.5.30 is dropping connection. After update of some versions, this beahviour is happening. I thought with the updates of this last version it would stop, but it coninues...
Aug 29, 2019Guru - Experienced User
Wrong. My system IS working. Plain and simple.
Retired_Member
Aug 29, 2019
FURRYe38 wrote:Wrong. My system IS working. Plain and simple.
and your assumption is if it works for you it should work for all.
- FURRYe38Aug 29, 2019Guru - Experienced User
If you believe that. Good Luck. Now lets get back to the OP.
- Retired_MemberAug 29, 2019
FURRYe38 wrote:If you believe that. Good Luck. Now lets get back to the OP.
I never left the OP...you're the one with this post..."I have had zero issues with v30 on my RBK50."
- MatheusFigueireAug 30, 2019Aspirant
Great.
But my model is RBR50, and with the latest firware i started to have this basic problem.
It is discouraging.
