MatheusFigueire
Aug 28, 2019Aspirant
Orbit RBR50 dropping connection
ORBI RBRB50 with Firware V2.3.5.30 is dropping connection. After update of some versions, this beahviour is happening. I thought with the updates of this last version it would stop, but it coninues...
Retired_Member
Aug 29, 2019
FURRYe38 wrote:Wrong. My system IS working. Plain and simple.
and your assumption is if it works for you it should work for all.
Aug 29, 2019Guru - Experienced User
If you believe that. Good Luck. Now lets get back to the OP.
- Retired_MemberAug 29, 2019
FURRYe38 wrote:If you believe that. Good Luck. Now lets get back to the OP.
I never left the OP...you're the one with this post..."I have had zero issues with v30 on my RBK50."
- MatheusFigueireAug 30, 2019Aspirant
Great.
But my model is RBR50, and with the latest firware i started to have this basic problem.
It is discouraging.
- FURRYe38Aug 30, 2019Guru - Experienced User
Yes the system should work with little configuration. However some have need for this.
Please also give feedback to the questions presented. This will help us with information about your envrionment and configuration.
Thank you.
MatheusFigueire wrote:Great.
It is discouraging.
