MatheusFigueire
Aug 28, 2019Aspirant
Orbit RBR50 dropping connection
ORBI RBRB50 with Firware V2.3.5.30 is dropping connection. After update of some versions, this beahviour is happening. I thought with the updates of this last version it would stop, but it coninues...
Retired_Member
Aug 29, 2019
MatheusFigueire wrote:ORBI RBRB50 with Firware V2.3.5.30 is dropping connection.
What can be done from NetGear ?
v2.3.5.30 has known problems.
MatheusFigueire
Aug 30, 2019Aspirant
RBR50
Hum, ok, and do you know when NetGear will release some update to fix those problems ?
This is a top product, it should not have basic problems like this.
IT should not be necessary to disable stuffs to have this working, it should work, at leat the basic.
