MatheusFigueire
Aug 28, 2019Aspirant
Orbit RBR50 dropping connection
ORBI RBRB50 with Firware V2.3.5.30 is dropping connection. After update of some versions, this beahviour is happening. I thought with the updates of this last version it would stop, but it coninues...
bjeronimus
Jan 13, 2020Aspirant
I have 3 Orbit RBR50 routers. Are they compatible with other Orbi router models?
Jan 13, 2020Guru - Experienced User
You can connect RBS 20/40 series satellies to the RBR50. RBRs can't work as satellites, only router or AP mode.
bjeronimus wrote:I have 3 Orbit RBR50 routers. Are they compatible with other Orbi router models?
