dr_dr_dr
Aug 02, 2021Aspirant
Orbit RBR50 is non-responsive
My Orbit RBR50 router stopped broadcasting my network. A reboot didn't fix anything. I attempted to do a factory reset, but noticed that the power light remained green the entire time and I am still ...
Aug 03, 2021Guru - Experienced User
Disconnect the ISP service LAN cable from the RBR.
Power OFF the RBR fully from the power outlet for 30 seconds, than power back ON.
Check to see if the top ring LED starts blicking ON and OFF. If it does, press the reset button in back for 15 seconds then release.
Wire connect 1 PC to the back of the RBR. If the top ring LED starts slowly pulsating ON and OFF, see if the PC and web browser can access the RBRs web page at 192.168.1.1. Check your ethernet adapter settings to see if it got an IP address from the RBR.
dr_dr_dr wrote:My Orbit RBR50 router stopped broadcasting my network. A reboot didn't fix anything. I attempted to do a factory reset, but noticed that the power light remained green the entire time and I am still unable to access the router. Is this thing bricked or is there some way of recovering it still?
dr_dr_dr
Aug 03, 2021Aspirant
Thanks for that. The top ring LED does not light up at all. Last night I attempted to connect to the router via a PC as you suggested, and could not do it. Couldn't even ping the router.
- FURRYe38Aug 03, 2021Guru - Experienced User
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
https://www.thewindowsclub.com/enable-tftp-windows-10- dr_dr_drAug 03, 2021AspirantI can't get the power LED to turn orange. When I turn the router on the LED turns green, regardless of how long I've held down the reset button.
Last resort would be to try this:
https://www.snbforums.com/threads/custom-firmware-build-for-orbi-rbk50-rbk53-rbr50-rbs50-v-9-2-5-1-18sf-hw-v-9-2-5-1-18-1sf-hw.64414/page-3#post-590839
https://community.netgear.com/t5/Orbi/Is-my-13-month-old-RBR50-bricked/td-p/2009904/jump-to/first-unread-messageIf this unit is under warranty, you should make contact wtih NG support to see what your options are.
