padave44
Dec 07, 2021Follower
ORBO (RDR50) no internet after upgrade to CM2050V
I upgraded my modem from CM500 to CM2050V. I thought it would be simple - called Xfinity and gave them the MAC adress. After they added the device, I rebooted CM2050V and RDR50. I looked at the ...
- Dec 07, 2021
Try this.
Power off the modem and the router and disconnect everything from both. (even coax from modem)
then connect the coax back to the modem and power it on.
Wait 2 minutes.
Then connect the lan cable from modem to wan port on router.
Power the router on and give it 2 minutes.
then try to go though the internet setup process on the router.
If that doesn't work, follow the same procedure but connect a pc/laptop to the modem instead of the router.
make sure the modem is working and that it was provisioned correctly.
Dec 07, 2021Guru - Experienced User
Try this.
Wait 2 minutes.
