jimcall37
Oct 31, 2017Aspirant
Orbo Satellite blue light keeps turning on then staying on for a while
I have two satellites, but only the one has the blue light turn on. I have reset it, resynced it, but it continues to have this issue. It was in the bedroom, but I switched it out with the one in the ...
jimcall37
Nov 02, 2017Aspirant
Hi. The sattelite is the RBS50. I have tried multiple times turning it off, waiting, then turning it back on.
ElaineM
Nov 03, 2017NETGEAR Employee Retired
How long have you had the kit?
When did you start experiencing that issue?
Have you tried moving it closer to the main router?
I suggest for you to reset it with a paper clip once again and if that didn't work register the kit in order to log a case.
- jimcall37Nov 08, 2017Aspirant
Hi. I have owned the kit for a little over four months. The issue has been going on consistantly for about a month. I have reset it with a paper clip, but I certainly could try that again. The first time I reset it I had moved it much closer to the router.
- tagteamNov 08, 2017Virtuoso
You can also try unchecking the "Enable Daisy-Chain Topology" box in the web GUI under Advanced>>Advanced Setup>>Wireless Settings.
When my system auto-upgraded to the 2.0.0.74 firmware, I discovered that box was checked and I believe it is the default. Regardless, the LED on one of my satellites was cycling from OFF to BLUE to OFF as it randomly connected to the other satellite and the router and back to the satellite. Unchecking the "Enable Daisy-Chain Topology" box resolved that issue immediately.
- jimcall37Nov 22, 2017Aspirant
Hi. I appreciate your suggestion, but unfortunately it didn't work for my satellite. So, it looks like I'm at a loss as to how to fix it.
