PB21UK's avatar
PB21UK
Tutor
Mar 24, 2019
Orbo update file faulty RBS40V-V2.3.0.10
I've downloaded the latest update this morning but after unzipping the file contained in the zip it is not the correct format, so the update will fail whichever method you choose auto or manual.   ...
