PB21UK
Mar 24, 2019Tutor
Orbo update file faulty RBS40V-V2.3.0.10
I've downloaded the latest update this morning but after unzipping the file contained in the zip it is not the correct format, so the update will fail whichever method you choose auto or manual.
michaelkenward
Mar 25, 2019Guru - Experienced User
Try changing the name from *.chk to *.img.
antinode
Mar 25, 2019Guru
> [...] after unzipping the file [...]
Your attached picture shows what's in the zip archive; it does not
show that you've extracted the file(s) from the archive. Which you'd
need to do before you could load the ".chk" file into the router.
> [...] contained in the zip it is not the correct format, [...]
Says who? Some zip/unzip program or other?
> [...] so the update will fail whichever method you choose auto or
> manual.
Says who? Did you try it? How exactly?
https://community.netgear.com/t5/x/x/m-p/1724099
That sounds to me like a seriously poor idea. Have you ever actually
tried it? On anything?
