mohdasti
Sep 23, 2020Aspirant
Orboi router solid magenta — no internet
Hi, I hope this is not a duplicate question. It's been hours that my ORBI router ring is purple (magenta). I unplugged everything. i rebooted the modem. I reset the modem. I reset the Orbi system 4 ...
mohdasti
ISP : It's Carry Telecom (third-party of Rogers).
Router is connected to the Hitron CGN3U modem. Earlier today, I bypassed the Orbi and I do have internet connection with their provided device.
Yes, I rebooted everything. Even pushed the factory-reset on both modem and router. I also changed the cable but the ring is still magenta.../
Mstrbig
Sep 23, 2020Master
mohdasti wrote:ISP : It's Carry Telecom (third-party of Rogers).
Is the Orbi in router or AP mode?
After you pushed the factory reset, did you re configure the router?
- mohdastiSep 23, 2020Aspirant
The Orbi router was not in AP mode. I changed it, and now the magenta ring is gone but, I still do not have internet connection! That's really odd
And yes, I re-configured the router after factory reset.
(thank you by the way. I really appreciate it)
- MstrbigSep 24, 2020Master
mohdasti wrote:The Orbi router was not in AP mode. I changed it, and now the magenta ring is gone but, I still do not have internet connection! That's really odd
See if this works:
Make sure your ISP router is set as a router and the DHCP server is active. Then reboot your ISP router.
