Euler13
Jun 25, 2018Aspirant
Orib Satellite Drops Connection
Greetings! I'm new to the community and I've just splashed out on an Orbi RBK50 AC3000 Router + Satellite to replace homeplugs and wifi-extenders. I setup the system on Friday (three days ago) and si...
Jun 26, 2018Guru - Experienced User
Yes, use the modems DMZ and if the IP address the Orbi router is getting 192.168.0.22 then input this IP address into the DMZ ON the modem. Set up a IP address reservation as well for that IP address ON the modem.
- Euler13Jun 26, 2018Aspirant
I've reserved .22 for the Orbi router. When I set the DMZ I can only set one IP address and the hover link says, "Enter the last field of your host's IP address. For example, if the host's address is 192.168.0.154, enter 154." I have other devices that are using greater than .22, will this be a problem? I have no idea what I've just done by adjusting that setting. Also, does it matter if the IP address for the satellite is not reserved? Currently that is on .24.
