wfinley
Dec 17, 2020Aspirant
orib satellites losing contact with base
All, After a few days, the wireless network becomes unstable and has long stretches of ping failures to orbilogin.com. Since this is 100% internal ping, the ISP or router is not involved. ...
vajim
Dec 17, 2020Master
what's the ring color of your Sats?
- wfinleyDec 17, 2020Aspirant
when I have short intermittent drops, there is no color on the ring. If the drop lasts more than a minute, the ring turns purple.
also, when the drops occur, none of the devices directly plugged into the satellite's network ports can ping the satellite's IP.
- paul1315Dec 17, 2020Aspirant
I added another satellite to my Orbi Pro system a couple of weeks ago.
up till then it's been pretty good for over a year, but the new satellite wanted a firmware update, and this same update went to base and other satellites. System has been unstable since with satellites randomly losing connection to the base ever since. Same behaviour as op describes with ring going purple.
Is this likely to be another suspect firmware version. It's the latest available as of a week or so ago.
