Logo_guy
Sep 10, 2020Aspirant
Oribi RBR20 loses connection on a daily basis
Almost every single day I lose internet connection with this router. I call my internet company and it shows no inturruptions on internet and they suggest to me that it could be the 3rd party router....
Sep 10, 2020Guru - Experienced User
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
- Logo_guySep 10, 2020Aspirant
Okay, that's a lot of info. Let me get it all answered. May take me a bit.
