AJH4
Mar 16, 2021Aspirant
Original Orbi with V2.7.2.104 WiFi Connected, Satellite Connected -- some devices no internet
Orbi RBR50 (V2.7.2.104) with one Satellite has dropped internet for some devices connected via wifi. No changes to anything since the last time everything worked. Reset modem and reset Orbi did not work. Settings are optimized as per various instructions. Devices that are connected via ethernet not impacted. Some devices on wifi not impacted. Does not seem to be tied to one frequeny -- happens on both 2.4 & 5 range. Tried flipping channles too.
This is from a set installed SEPT 2017.
Time to retire and replace? Failure has been sudden and not seemingly tied to a firmware update, new devices in house, damage, storms, etc.
1 Reply
- vajimMaster
AJH4 wrote:Orbi RBR50 (V2.7.2.104) with one Satellite has dropped internet for some devices connected via wifi. No changes to anything since the last time everything worked. Reset modem and reset Orbi did not work. Settings are optimized as per various instructions. Devices that are connected via ethernet not impacted. Some devices on wifi not impacted. Does not seem to be tied to one frequeny -- happens on both 2.4 & 5 range. Tried flipping channles too.
if you'll do a search in this forum, you'll see lots of problems with V2.7.2.104
