wifiblues
Jul 09, 2020Luminary
original password
i am upgrading my orbi router and sattelite to RBK43. I purchased a used Orbi from a friend. how do i reset the wifi password back to the Orbi given one? thanks. wifiblues
- Jul 09, 2020
I would use a wired PC and web browser to walk thru the setup wizard.
Jul 09, 2020Guru - Experienced User
Press the reset button in back for 15 seconds then release. Wire connect up a PC and walk thru the setup wizard.
wifiblues
thanks - and do the same function for the satellites?
- FURRYe38Jul 09, 2020Guru - Experienced User
No, but you can if yon want to. The login info and pw will be confgured automatically on the RBS once it's synced to the RBR.
- wifibluesJul 09, 2020Luminary
that sounds easy. I am just a novice! Can I set up the new router using the same Orbi app as the current router? the Orbi app does give an option for a new set up.
when I scan the code for the new router, will the wifi password it is using display?
