wifiblues
Jul 09, 2020Luminary
original password
i am upgrading my orbi router and sattelite to RBK43. I purchased a used Orbi from a friend. how do i reset the wifi password back to the Orbi given one? thanks. wifiblues
- Jul 09, 2020
I would use a wired PC and web browser to walk thru the setup wizard.
wifiblues
that sounds easy. I am just a novice! Can I set up the new router using the same Orbi app as the current router? the Orbi app does give an option for a new set up.
when I scan the code for the new router, will the wifi password it is using display?
Jul 09, 2020Guru - Experienced User
