RussFogg
May 28, 2019Tutor
OSX location services not available
Hi, I seem to have this strange situation when I am connected to my Orbri Wifi network and then my Macbook cannot pickup a location under location services, if I hotspot to a iOS device which is ...
Talk2Mike
May 28, 2019Apprentice
I have no issues with my MacBook and location services when connected to Wi-Fi via my Orbi.
Are you you sure you don’t have a double NAT issue by running the Orbi in router mode while your model or old router is still in router mode?
- RussFoggMay 28, 2019Tutor
No double NAT as Orbi is the only Wifi kit running, no ISP router and the Orbi get's an WAN IP address from the ISP and then uses DHCP to create the internal network
