1qwerty1
Feb 25, 2020Tutor
Outbound traffic to Amazon space
Hello, I am wondering why my Orbi AC2200 unit (running latest firmware as of 2/23/2020, RBR20) is constantly making outbound connections to the Amazon space (52.0.0.0/11) over SSL/443. The home ...
1qwerty1
Apr 14, 2020Tutor
After mocking around, here is my final list of rules with FQDNs/subnet to block/allow (in the top-bottom order, src: Orbi router + satellite):
ALLOW:
www.netgear.com AppID: ping
DENY ANY:
devicelocation.ngxcld.com
fw.updates1.netgear.com
genieremote.netgear.com
http.fw.updates1.netgear.com
peernetwork.netgear.com
presence.ngxcld.com
readycloud.netgear.com
readyshare.netgear.com
registration.ngxcld.com
DENY: 52.0.0.0/11 AppID: Any
DENY: AppIDs: aws-iot, ftp, ping, ssl, web-browsing
icuhackn
Apr 14, 2020Tutor
this is great, thanks! I just set mine up. Do you see this destination in your PA logs for ICMP?
( addr.dst in 192.168.0.120 )
I can only assume that perhaps the wifi backhaul is using that address; however, I cannot see anywhere in the WebUI configuration or general documentation that says what network it uses for backhaul connectivity between router and satellite Orbi. I have the AX6000 series devices.
Thanks!
- CrimpOnApr 14, 2020Guru - Experienced User
The Orbi WiFi backhaul is a 5G radio link directly between the router and satellite. Since it is encrypted in a WiFi signal, I doubt very much that this traffic will be "capturable". (word?)
- 1qwerty1Apr 15, 2020Tutor
Re: the outbound 192.168.x.x address pings
In my logs since the day I installed the Orbi, i see one icmp outbound packet from the Orbi router per day to 192.168.100.1 which gets denied by my src:any dst:rfc1918 subnets rule. I am not sure where this comes from.
Btw, if you would like a complete list of URLs your Orbi devices are configured for, telnet to your router, and:
root@RBR20:~# grep -rw '/etc' -e 'https:'
Some of the domains are not related to our devices, however, a few more popped up in the config (I don't see these in the pcaps):
advisor.qa.arloxcld.com
registration.qa.ngxcld.com
presence.qa.ngxcld.com
updates.netgear.com
genieremote-qa.netgear.com
devcom-qa.up.netgear.com
arlo-device-staging.messaging.netgear.com
devicelocation.dev.ngxcld.com
devicelocation.qa.ngxcld.com
redmine.lighttpd.netIt probably won't hurt to block these as well.
- FURRYe38Apr 15, 2020Guru - Experienced User
192.168.100.1 maybe your upstream modem? Stand alone modems usually use this address for there web page access.
